3500_6.5
Yes it does. I had an issue when the truck had sat for a couple months where it wouldn't shift out of first gear. I unplugged the controller and plugged it back in and it was fine. Not sure why it did that, it had no codes stored in it or anything. Other than that it has worked without issue.
One thing I want to do, that I haven't had a chance to do yet, is hook up a switch to change the transmission settings. It came with a switch that you could hook in to have two separate transmission settings. How I have it set up now works about 95% of the time. But with a heavy load and long steep grades it doesn't like to unlock the converter soon enough and then likes to re engage it too early. I would like to set it up to where my second setting has firmer up shifts and easier unlocking of the converter. It can be fine tuned pretty well, so I think I can get it similar to like a tow/haul mode on the Duramax's. Just have to take the time to do it...
