- Staff
- #61
Once you remove the xmember you might be able to sit the motor lower in the rails to add more hood and firewall clearance.
Source Unknown
Hood clearance IS an issue, but firewall clearance is not an issue. Also if you go ahead and do the SFA, it will make putting the engine in ALOT easier. Getting the engine in around the front diff was not fun to say the least, and if you took out the IFS you could slide the engine back a good 2 inches making clearance for the radiator and intercooler a lot easier to obtain. The cross member for the torsion rods keeps you from moving the engine back very far, but if it wasn't for that you could go back with it.
