Just bought a complete (supossed running) 6.5 for $50 Actually I turned my brother onto it. If he did'int grab it I was going to.
You may get something for the heads?
o wow i wish i coulda found that deal before i bout the donor. but ya im not trying to get rich off the engine just dont wana throw it away some1 has gotta need something somewheere haha
I used 3/16" on mine, and even that was pushing it for thickness with the stock 4 bolt mounts. I ended up grinding reliefs in each of them for the 2 humps on the mount to fit down into. I tried to sit my engine as low as possible, and it still rubs the hood some. It will be a TIGHT fit with it in there. I have MAYBE a 3/8" clearance on the oil pan to the steering linkage, and my A/C lines and air intake rub the hood on top. If you could slide the engine back you could get more room, but then you run into a whole host of other problems(transfer case will hit the torsion bar cross member, the steering shaft will hit the drivers side manifold, and a stock truck oil pan will hit the steering center link).
2" body lift a possibility to help clearances?
Thats what that outfit out west (colorado IIRC) does when the drop a dmax in.
IIRC Ferm said that he saw where that would help but didnt want the lift.
