Nick 6.5
Active Member
i havnt been able to find any solid reviews of the diamond eye down pipe. do u have an opinion on them? or any other down pipe u have in mind?
I do plan to run 600 max rwhp with a selectable tuner like the banks 6 gun for economy tow and hp settings. i also want the downpipe for lower egts and cause im doing an egr delete.
I can pull 26K w/ a nearly stock truck. 600hp isn't needed in a towing rig, if anything that will make it less reliable.
Subscribed. How the hell do you guys work on sand/dirt?
Best thing in my opinion is to mock the engine and axle up together. Then you dont get don with one item to find out you need change things around to fit the next item in the truck. Good Luck i'll be interested to see how it goes.
