n8in8or
I feel like that would go well with the sh!tty old tankToilet wax ring
Thanks Duvall!
I usetacould be able to lay TIG welds on thicker carbon steel that I wasn’t ashamed of, with practice I should be able to get there again and on a wider range of materials. This thinnish stainless in an awkward layout has proven to be quite a challenge for my rusty skills.
The lift pump is a gerotor. I would hope it would be easier for it to prime with the larger tube since the purpose of it is to make it easier for the pump to run, but I guess I’ll be finding out soon.
My return line for the pressure regulator return is -8 Russell Pro Classic II AN hose. My return mine for the IP and injectors is 5/16” 30r9 fuel injection hose.
The return-style regulator is probably overkill, but I’ve been wanting to try it for a while so I decided to give it a go while I had the opportunity.
I know that gerotor and vane pumps don't like to be dry. I think gerotor even more so. I'm sure the large tube will help with priming,. That's a large volume of air its got to get through first.
Did you decide to run hose rather than hard line for the ease of mounting?
I wouldn't say your return regulator is overkill. I know you are looking for 25psi at the IP. Your lift pump pressure must be well above that. Return style regulator will give you more consistent pressure at your injection pump. Its going to be a slick setup.
I never had problems with mine priming when it was in the Tahoe.I used my shop vac to blow into the tank to lightly pressurize it until the pump was primed. IIRC mine wouldn't prime on it's own
On gear driven pump, thats a sign of air leak. Usually, Gear pumps are self priming, and can draw into vacuum easily.I used my shop vac to blow into the tank to lightly pressurize it until the pump was primed. IIRC mine wouldn't prime on it's own
The carbon drawn to the surface creates hardening of the steel on the surface and vibrations and rattlings will help to promote cracks and cracking.Thanks for mentioning this. I don't know about cracking, but I totally flaked out on the carbon promoting corrosion. I have some stainless wire wheels on order and I'll be cleaning it up after I receive those.
I put KBS Rust Seal on the lower half of the tank and on the tank under the crossmembers on the top.No por15 on the tank ?
UV degrades POR15, better products is the one Nate mentions and DuraBak which has UV inhibitors and is MIL SPEC. US NAVY uses it.No por15 on the tank ?
Rust Seal also degrades from UV, but it will see limited UV where it is under the truck. I'll have to look into that DuraBak.UV degrades POR15, better products is the one Nate mentions and DuraBak which has UV inhibitors and is MIL SPEC. US NAVY uses it.
Yeah there’s a lot of room back there when the factory fuel and wiring are cleaned up. A picnic isn’t really the thought I had in mind for that space though.....You could have a picnic in the space above the transmission.
