Hmm, I’m not sure I follow. Maybe what you’re seeing is the return line that no longer follows the valley of the block and normally runs over the bellhousing? I rerouted that to drop off the driver side front of the engine. That’s the rubber hose without the nylon braided outer layer.So I have to ask Nate is there an extra line tying into the return line near the IP?
Nope, the plumbing is complete. I'll take a video later to explain the plumbing up at the engine, that will probably explain better than pictures and words.So you put a T fitting there?
A double-feature and half a bag of microwave popcorn.Nice job, Nate! What do we get for a quarter?
That will be WAY more than a quarter and that's still in pre-production. I'm currently looking for a skid-steer doubleGee, is the Second Feature a video tour of your (finally) completed skid steer, Nate?![]()
Partially. The main purpose of the oil presser sensor is I'm still using that as the main trigger for the lift pump relay, but yeah, I also left the factory gauge functional, mostly just so I didn't have dead gauge in my cluster.So the sensor on your oil pressure line is so you can have a light/guage as well as a mechanical guage?
Yes, it is exposed to UV via reflection, there are water based UV rejection coatings that can be applied to hoses, interior components and other items. Many individuals are using DuraBak smooth to coat tires for protection from UV...Rust Seal also degrades from UV, but it will see limited UV where it is under the truck. I'll have to look into that DuraBak.
AWESOME...This weekend I got the pre-IP fuel filter mounted. I had been planning on mounting it to the fender or core support, but Friday night I was looking at things closer and determined I could hang it off the alternator bracket. This is a good thing because now I can finish all fuel plumbing before hanging the front clip. Unfortunately I need a couple different hose ends and won’t have those until Monday so I wasn’t able to finish the fuel system this weekend.
View attachment 63409View attachment 63410
I also got the fuel pressure and oil pressure gauges plumbed with -4 hose. The FP gauge hose is filled with antifreeze between the isolator and the gauge.
View attachment 63411View attachment 63412
I made a new block off plate for the rear of the passenger side head and tapped it 1/2” NPT for the water temp gauge. And hooked up the EGT probe.
View attachment 63413View attachment 63414
Thank you. I based a lot of the supply end of this on info you shared. I can’t wait to see the results.AWESOME...
