As far as sealing it all when your done, install it on the tank, when it's all finished melt a pot of way and pour it on and let it cover the entire area and even on the tank area, if you can find bees wax that would work well....
Love this idea! I was thinking about putting paint all over the flange and ring, but cringing at the thought of having to disassemble it if that ever became necessary. This will work awesome, thanks for the idea!!As far as sealing it all when your done, install it on the tank, when it's all finished melt a pot of way and pour it on and let it cover the entire area and even on the tank area, if you can find bees wax that would work well....
I can ride my gas tank like a kayak!Or you can use some of that shit from the TV Infomercial where the guy makes a bass boat out of chicken wire and his miracle coating!
What the factory did or what I could do?Roofing tar for a sealer?
Thanks for mentioning this. I don't know about cracking, but I totally flaked out on the carbon promoting corrosion. I have some stainless wire wheels on order and I'll be cleaning it up after I receive those.If the welded together sending unit/fuel tube system can still be removed, use a bead blaster, wire brush or grinder and remove the blued steel from the tubes especially. That blue is carbon drawn to the surface and will promote cracking. just sayin.
Thanks Duvall!Good work Nate!
All that welding will look good under the bed, just like my welding.
Is your "lift" (dare I call it that) pump a vane or gerotor type? I'm curious how it will prime the first time with a pickup tube that big.
What type of return line are you running? Tube rather than hose I would assume?
I decide to go with a deadhead type regulator with what I am doing. I didn't feel like running another return line and it should be fine with my low pressures.
