1969 IH 1300D 4X4 - Pump Truck
Did some looking on eBay. Kinda disappointed as several I looked at have needles that dont return to zero. And some sellers picture it but dont mention it.
There are several different ones ranging from 3/8 to 1/2 measuring to 75, 100, 140 and 150 foot pounds. Found 1 in a nice box confirmed to rest on zero in neutral but its $75. A little steep for my purpose right now. Thinking this is a $30ish dollar purchase.
Might end up getting the cheapie duralast and will compare to a clicker type or something for now.
Quite a few craftsman on ebay too. I wouldn't get too excited about the pointer not pointing to zero as it is just a pointer to show how much the main beam is deflecting. should be able to easily tweak it back to zero
Mine isn’t exactly at zero. I just keep that in mind when using it and compensate for it.
Helicoils came in:
Got one of the Helicoils installed, but had to stop on the other. I don't have a 33/64's drill bit.
Going to get out today and get the torque wrench. I put out a few bids on select 1/2'' craftsman wrenches on eBay (looking for the 0-100 ft lbs model) but if I'm successful it wont get here for a week or so I bet.
Lunch fun, Finally getting some visual progress back on the truck.
Picked up the Duralast "Made in Taiwan" torque wrench. Decent looking unit and did what I needed it too. Specifications call for breaking torque between 20-40 ft. lbs. as acceptable. I would say its just within spec at 21-22 ft. lbs.:
Installed the new knuckle seals, a bit tricky keeping the rubber seated, getting the felt on and then getting the bolts through the retainer and the felt to pinch it all together:
Slid the axle shaft in after lubricating the seal areas with gear oil and loading up the knuckle with Corn Head lube (the easy way):
Installed the backing plate and spindle assembly. Utilized some form-a-gasket behind the spindle to seal to the knuckle as upon disassembly a seal wasn't present:
For now I am stuck here until one of the following are ordered:
  • 33/64 drill bit for the drivers side remaining Helicoil; or
  • Wheel Cylinders, brake shoes and hardware to keep going on the passenger.
I think about 4 or 6 pilot bolts would help to get them knuckle seals slid into position.
I have a drawer of My tool box with a pretty good supply of them things just waiting for their turn to be employed. LOL
With that new paint and everything cleaned up, it sure does look nice.
That's how I started it 3 bolts per half moon retainer, but the issue I ran into was threading the bolts in through the felt, it just didn't line up quite right so I had to do a bit of finagle-in' due to the awkward position of this thing. Anywho; only 1 more to go, luckily this thing doesn't have quadra-steer!
Brought in my small dremel stones and cleaned up the burr on the one hub:
Noticed in the picture I posted yesterday 2 bolts had red paint left on the heads, couldn't have that. So I cleaned them up some more, much better:
Prepping the drivers side:
I purchased a 33/64's drill bit last night, hopefully with Prime it will be here by Friday. I also need to get a replacement lock washer for the backing plate/spindle bolts as one of the ones removed was a 2-piece. Might do some wandering at Napa today for wheel cylinders. I could save $10-15 each from RockAuto but am worried of picking the wrong thing.
Some artistic painting of the bolt heads. Waiting to do the brake line one:
Cleaning of the drive flange hardware:
Replacement kingpin lock washer:
Are you cleaning all of your hardware with a wire wheel or are you using some other process like ultrasonic?
Are those nuts locking or using a cotter pin? If they're locking you might consider peening the top of them to tighten them up after chasing them with a tap
