DieselSlug
Had a little progress today.
After leaving this joint soaked for a few days 2-pops and it came loose:
The knuckle seal plate bolts were coming out a little tougher on this side compared to what I remember of the passenger side. A closer look and some of the threads seem stripped. Will have to make sure I chase them good and maybe get some new bolts upon re-assembly. I made note of it on my little baggy of hardware:
Bolts and backing plate removed looking at the felt wiper assembly:
Pulled the axle shaft out. Of course I jinxed myself saying earlier that the shaft slides right out with the knuckle on (which it should). However, this was was a bit tougher. Needed to clock it a few times to find the sweet spot where it clearance-d out of the knuckle. Also the bronze bushing came out with this side:
There is some light at the end of this front axle re-fresh....:
Parts are stacking up for cleaning and repainting:
As it sits:
As it sits:
