Will do. Is there an easy way to check without counting?There were NP 241s with 27 splines and 32 splines on the shaft. I think the 1500s had the 27 splines, while the 2500 and 3500 had 32 splines. Be nice if you could check.
Take a pic and start counting?Will do. Is there an easy way to check without counting?
I was hoping there was a number on the tag. Even easier, if that was the case.Take a pic and start counting?
I etched a scratch in one groove and moved a screwdriver over the splines counting until I got back to the etch. Pretty easy.
Nope. I guess you could measure it?I was hoping there was a number on the tag. Even easier, if that was the case.
Measuring only works if the splined are the same size as opposed to the shaft.Nope. I guess you could measure it?
I went out and measured it with the calipers and got an ID measurement of 32.5 to 33.0 mm
I was tempted to split the case today, but I just e-mailed the vendor instead, including the pic of the model tag. They should know w/o my having to split the case. I don’t want to get all dirty just before family comes over.I think the kit looks like a solid & quality package
There is the spline difference, and different input shaft bearing sizes between the 94 and 95 model years. I think the cases will swap into the truck no problem. But if you want to rebuild the spare 95 it's best to open it up first and verify input shaft bearing size and the chain width & number of links. That way you know for sure what rebuild kit to get
32 spline. Looked to be about 34 mm OD to meNope. I guess you could measure it?
The input measures about 30.4 mm at the outside of the spline according to my harbor freight digital caliper that I don't trust for anything.Nope. I guess you could measure it?
I measured between splines. Harbor Freight digital. 32 spine is pretty much what our Chevy’s got.The input measures about 30.4 mm at the outside of the spline according to my harbor freight digital caliper that I don't trust for anything.
48.43 OD.
Thanks. Is there another vendor that sells a more complete kit?94/95 was a crossover year for that transfer case, so still probably best to split it to find what size input bearing it has. As far as I know you can't decipher model year from the tag on the 241, which is probably why the vendor went by VIN
I've split a 241 open several times, they are really simple and not difficult to work on when it comes to seals, chain, and some bearings. There's a few blind hole bearings that will need some kind of puller if you want to go that deep into it. Some just leave the bearings and do the seals, plastic tabs on the shift fork and call it good. Getting the rear output shaft assembled is a bit tricky with the oil pump sliding around and pickup tube easily dislodged. Just take it easy going back together and you'll be good.
I don't see this bushing in the rebuild kit, it's for the tail housing, link if you want to go the extra mile
BW4444 BW4445 BW4485 MP1222LD MP3023LD NP246 NP149 NP136 NP208 NP231 NP236 NP241 NP261 NP263 MUNCIE SUPER T10 8L90 TRANSMISSION & TRANSFER CASE EXTENSION HOUSING BUSHING (WT297-62)
BW4444 BW4445 MP1222LD MP3023LD NP246 NP149 NP136 NP208 NP231 NP241 NP261 NP263 MUNCIE SUPER T10 TRANSMISSION & TRANSFER CASE EXTENSION HOUSING BUSHING (WT297-62)www.transmissionpartsdistributors.com
Also I suggest this upgraded snap ring as part of the output shaft assembly, much sturdier than factory and prevents future problems of the slip yoke repeatedly slamming into the single snap ring
NP231 NP233 NP241 NP243 TRANSFER CASE OUTPUT BEARING SPLIT RING RETAINER KIT FITS MODELS WITH 32-SPLINE 1.375" SHAFT BY SONNAX
NP231 NP233 NP241 NP243 TRANSFER CASE OUTPUT BEARING SPLIT RING RETAINER KIT FITS MODELS WITH 32-SPLINE 1.375" SHAFT BY SONNAXwww.transmissionpartsdistributors.com
Finally when re-sealing everything Permatex Optimum Black is my recommendation, a hard gasket maker did not play nice with my case. I use Optimum black on pretty much everything with great results. I also run TriboDyn 75W90 gear oil in my case instead of ATF, but I'm putting a lot more abuse on my rig so either would be fine for your application
I’ve watched a number of videos on this and it does seem pretty simple, but I do have questions.I purchased a few kits and a chain from Transmissionpartsdistributors.com as I couldn't find a kit like the one you found (didn't really look too hard on ebay I guess) and it seemed to be a bit cheaper to buy the bearing and seals kit, the small parts kit, and the chain to make my own kit
I got the bearing and seals kit for '95: (note if you need the larger input bearing for '94 the SKU is BK241)
NP241 TRANSFER CASE REBUILD KIT FITS '95-'99 GM & '94-'01 DODGE LD WITH 16mm THICK 6010-N INPUT BEARING (BK241A)
NP241 transfer case rebuild kit BK241A 16mm input bearing gm chevy dodgewww.transmissionpartsdistributors.com
The small parts kit:
NP241 NP241C NP241D NP241DHD NV241 NV241J NV241OR TRANSFER CASE SMALL PARTS KIT: SNAP RINGS, WASHERS, FORK INSERTS ETC FITS '88+ CHEVY GMC JEEP & DODGE (SP241-50)
NP241 NP241C NP241C NP241DHD TRANSFER CASE SMALL PARTS KIT: SNAP RINGS, WASHERS, FORK INSERTS ETC FITS '88+ CHEVY GMC JEEP & DODGE (SP241-50)www.transmissionpartsdistributors.com
and the chain:
NP208 NP241C NP241D NP243C BW1370 BW4401 TRANSFER CASE CHAIN 1.25" WIDE FITS CHEVY GMC DODGE JEEP BORG-WARNER HV-025
NP208 NP241C NP243C BW1370 BW4401 TRANSFER CASE CHAIN 1.25" WIDE FITS CHEVY GMC DODGE JEEP BORG-WARNER HV-025www.transmissionpartsdistributors.com
I also had to get the bushing I linked to earlier separately as it doesn't seem to be considered an internal wear part.
As I'm sure you've read about these rebuilds, one of the first things that wears out is the plastic tabs on the shift fork. Which is essentially why I got the small parts kit. You can also see in the small parts kit how feeble the snap rings are, don't even have tabs on them for snap ring pliers, which is why I really recommend the upgraded ring for the output.
I still haven't torn into my grenaded unit, but when I pulled the shift selector sensor it was covered in fine shavings so who knows what kind of grinding was going on. If you split the case and everything looks really good inside you could probably get away with just replacing the chain, plastic tabs and seals as the bearings are known to hold up for hundreds of thousands of miles.
