It currently runs and idles well,probably a tad smoother than prior to me swapping out injectors, though nothing crazy different.
It still smokes alot during a cold start, which Im starting to atribute to the timing being out of wack, cold advance solenoid not working properly, or, the glow plugs not firing up as they should.
It gets down to -20°F where im at, I need to winterize this vehicle, as my impala has begun to sound horrible (https://photos.app.goo.gl/JrGpXXKBR7WveuLX7)
What do you all think? Ill get the timing done at a Diesel shop, but thoughts on the other factors that I have listed?
That is smoother? That thing is shaking a LOT. That is a rough idle.
Does it idle smoother after being warmed up?
Positive no air through ip?
Yes get the timing adjusted. The timing adapters are getting more expensive. But read this post if you want to get the tools yourself. You need this adapter piece and an old school timing light. On amazon they are $230 now.
For the db2 a simple gasser timing light and one of these is all thats needed
Incase the link dies look in picture.
There are many manufacturers of these i just grabbed a random one of ebay.
The picture is of my Mac Tools branded one. ET18DPM is the part number. You clamp the sparkplug pickup clamp on the red loop of the tool. Clean the outside of the injector line and clamp on the ground clamp and pickup clamp.shoot light at timing gauge just like a gas engine. A local guy bought a $50 Taiwan unit 5-6 years ago and still uses it working in a diesel shop. Still works fine, that one sells for $75 last i saw. Really not the best for ds4 obviously but it will tell you your timing by the injection event to as accurate as you can see the balancer mark. So within 1 degree is not bad...View attachment 61496
Well it RIDES smoother, its always shaky on start up
Suspect the IP is wore out and or timing is off...
Are the timing lines lined up on the pump and cover?
The last time I checked, the lines were, someone did mention that me installing shorter injectors could have affected the timing by a hair and to get it checked out (which i will, given that i don't know when the last time this thing was checked at)
I was also told about the cold advance solenoid possibly not working aswell, which I could see as a possibility
I came across the video aswell, the more i watch it, the more i actually suspect that's also a factor
Tell me not my motor sounds similar to it
But what do you, and the others say?
