panran
Update…alright I purchased Leroy Diesel swollen glow plug removal tool and it worked flawlessly, I wasted some time trying other methods and no way would any other suggestion would have worked..and yes they were 11G …so I finally got fuel to all the injectors ( almost gave up until I reread some feedback and someone mentioned it would take a while) but then started leaking fuel in the valley and it seemed to be coming from the same spot as before…the key shaped seal that has the shape of a key…so have it apart again and noticed where the access to that seal is 2 screws hold it down and one of the holes had an obstruction and it looked like a tab on the end of a Heli-coil and it was so I removed it….thinking maybe it was keeping from setting completely…so we have been lucky with nice weather I’m going to put it back together tomorrow…but I have a question should I chance the Heli coil tab was causing it to not seat completely, or could I use a sealant like hylomar or permatex orange with the key shaped seal as extra security or is that not advised? Thanks panran
