J_dude
The point is just that the bulbs are a totally different size and shape (HID vs Halogen) so there is no physical way to make a reflector that is designed for a halogen bulb distribute light from an HID bulb in an effective, safe manner.
Can it sorta work? Yes.
Will people just suffer without flashing their hi beams at you out of fear that you’ll blind them even worse with yours if they do? Also yep lol.
It’s not the lenses, it’s the reflector.
Automotive lighting is actually a lot more high tech than it looks. The reflector is precisely engineered to direct light in all the right places, and none of the wrong ones.
And that little shield hasn’t much to do with it either, since the bulb doesn’t emit light from the front...
Anyway you’re response is basically what I expected. Sigh.
I repeat, check out HID Planet, there is so much more to lighting than most people think.
