I don’t want the truck to be that wide in the rear. I am thinking about using a regular SRW pickup axle though….that should only make me 2” wider on each side and then I wouldn’t need the inner spacer. If I could find a CUCV axle that would be perfect because it would also have 4.56 gears to match the front axle and it would have a Detroit locker in it.Any particular reason your not going to use a regular dually axle?
My primary design parameters are first, clearance around objects like trees and then second is looks (to me, narrower is better visually, cuz you know…..beauty is in the eye of the beerholder), plus the bed frame I have that I’m planning to use as of now is 92” wide, so that is about the width I’d like to stick to. That mockup was 90” wide overall, so I’m pretty much there already. Now having said that, this project is somewhat fluid and if I find a premade flat/dump bed that looks good and is a little wider, then a dually axle may be the route forward.Primary use is a question.
With those tires this looks to me like an off roader or working in dirt/muddy area.
If offroading and in tight areas like fitting past trees or boulder ridden trails, slightly narrower helps fit past thing. But if not fighting tight areas frequently, I would go for pushing them out more. Wider stance is more stability and imo looks better.
Also- if you ever do one for off roading adding some hmmwv “geared hubs” aka portals makes for some fun. 1.92:1 ratio jump, and easy central tire inflation on the fly...
Oh yeah! I forgot about that guy you went to…..and he has K30 parts? Nice! I’ll be in touch to get his info, sounds like I might have to take a run down there with a trailer.There are a few guys I know of one here in Ohio and the other in PA that sell rest free Square body parts. That where I got my roller from for my project. I'm sure you can find someone in Michigan that does the same thing. If not I can give you the contact information for the guy here in Ohio and see if he has any cabs. He had a TON of parts and a few cabs last time i was there, alot of K30 stuff.
Never mind, this plan won’t work because you can’t fit an inner dually wheel over a SRW drum.I don’t want the truck to be that wide in the rear. I am thinking about using a regular SRW pickup axle though….that should only make me 2” wider on each side and then I wouldn’t need the inner spacer. If I could find a CUCV axle that would be perfect because it would also have 4.56 gears to match the front axle and it would have a Detroit locker in it.
Ah yes. Maybe that’s the answer.Disk brake mod?
That it would. I was also thinking about moving the springs inboard a little since I’ll likely be fabbing my own mounts….I was just concerned about narrowing things too much. I suppose half an inch per side isn’t that bad, especially if I add an anti-sway bar.Air bags would free up all that wasted spring stuff room.....
Another person spending my money for me!might consider multi link with coilover
Free is always good for the project budget!This was free, so no matter what I found I was money ahead.
Yup!! That was exactly what I had socked away in my “next project” fund!Free is always good for the project budget!
