ak diesel driver
6.5 driver
I'd do the clutch before the rad.
That's not a good way to do it off the blocked off crossover passages on the back of the heads. Your routing is the same as the failed "flow increaser" Y hose sets (I won't mention Vendor names, but we all know the Blue silicone hose set with the fancy stainless steel machined Y connector that was supposed to prevent the #8 & #7 cylinder cracking on the 6.5 in HumVees by "improving" flow from the back of the head to the radiator) that did the same thing without the cooler.
Instead, consider using the heater core Send and Return hoses, either just tee-ing in for partial flow through the cooler, or diverter valves for full flow through the cooler only and none to the heater core(s) and remember to flip the valves the other way every winter so you have cab/rear heat, and back every summer for maximum auxiliary cooling..
Oh yes. In fact, it was found once (unlucky) users had used the Y flow bypass from the rear of the heads for a length of time, that it actually increased the coolant temperature at the rear of the heads and hastened head/cylinder failure due to the coolant flow characteristics of the 6.5. When they first came out, I too thought that the idea made perfect sense since racing SBC manifolds like those of Edelbrock used four-corner "X" coolant flow, but a SBC coolant flow path and relative coolant flow/pressures are much different than that of the 6.5.Didn't know that previous setup caused issues
Go take a road trip and drive it up to see @ak diesel driver this December!Interesting, missed it when all that was happening. Well T ing off from the heater would work well enough since the filter could be plumbed in before the T, providing filtering capability year round. Then divert to a second cooler in warm months if the temps won't stay down after the upgrades are done.
Yes a filter would reduce some flow to the heater core. Whether enough to be an issue come winter time if traveling to a colder area...... In Texas not an issue haha
Didn't want the Tejan to freeze and shatter in -30°F!Jan and Feb are the coldest LoL
That happens at 65F hahaDidn't want the Tejan to freeze and shatter in -30°F!![]()
With humidity, nice and dry it can be down to 55f !That happens at 65F haha
Be careful there young feller, or, You’ll have that old beast like brand new.![]()
