Loganshaw_6
Member
Yes lift pump is working will run with t handle valve openIs the Lift Pump PUMPING?
PMD is relocated behind the grille with a heatsink. No lights no codesYou have the PMD on a heat sink or on the pump? It will overheat and burn out without a heat sink.
The hole in the black wire loom in the left of your picture : are there rubbed through wires in it?
When the truck stalls after warm up: what are the dash lights doing? SES or STS lights come on?
Here is detailed troubleshooting of the PMD that dies in a codeless way. It's buried in the cal resister PDF. https://www.thetruckstop.us/forum/t...-5-db2-5-7l-info-online-from-stanadyne.26581/
I've checked the wiring pictured it is not into the actual wiring just on the insulation.PMD is relocated behind the grille with a heatsink. No lights no codes
That would be greatly appreciated. [email protected] is my email.The best I can do on my phone. You should be able to zoom in on them.
If anyone ever needs wiring diagrams let me know. I have Mitchel at work.
Edit: well I guess you cant zoom in enough to read them. Maybe I can email them to you.
I haven't pulled the loom off but I'll give it a shot. It's an extension kit I got off of Amazon so I have my doubtsHave you checked the PMD extension harness? I had similar issue, heat made it worse, some of the pins were bot crimped. And the cheap wiring even was cracking.
I was just researching a db2 swap... Is the db2 pump 100% mechanical so that if my truck does have an electrical problem that it will not effect it? I've gone over the truck and checked all recommended potential problems and have found nothing that looks out of the ordinary. I found another forum about somebody having a similar problem but there was never a resolution for it. I also attempted to unplug my coolant sensors and the truck still shut off. Fuel pressure looks ok, I even jumped the lift pump. Nothing...Leroydiesel.com for your next one.
Spare pmd is like a spare tire. If you are gonna own a ds4, that is the price of admission. Many keep the spare in glove box but what I suggest is have two PMDs mounted on heatsinks next to each other. put a dummy plug in one to keep the contacts clean and run the other one. When there is a problem just swap the wire over and your diagnostic is done, or you are back on the road in 5 seconds.
So if you are looking for an excuse to ditch the cheap one and you don't have a lifetime warranty pmd, get the complete kit and run on the new one keeping your old that's already mounted as the spare. When the one from Leroy dies, run on your old pmd and ship the toasty pmd back for replacement. Obviously run the quality cable that comes from Leroy.
If you don't want to sacrifice the amazon cable to use as dummy plug, the are available from ModMafia / bluehummer pretty cheap.
The REAL long term fix is loose the ds4 for the db2...![]()
Not what I asked. When it STALLS what are the lights on the dash doing? Generally the SES light will come on. What I am asking is if the ECM still has power: thus the interest in the dash lights. At this age fusible links are suspect as well as ign switches.
Eliminate the PMD extension cable for now as Amazon China Crap is suspect and a known source of problems as mentioned. Just move the PMD with heatsink by the pump for testing. People simply don't know there is better USA made PMD cables for a non-stop problem area. Of all the things I killed on a 6.5 the USA PMD cable (used in AZ) wasn't one of them...
Codes can take 30 seconds or longer to set thus the reason these primitive ECM's are useless esp. for PMD failures. You stall quicker than 30 seconds and then the tests / program quits running... 30 seconds is to eliminate intermittent noise or connection problems from setting a nuisance code.
I hate to say it... but it sounds to me like you may have another bad injection pump. Get it warm to the point where it stalls and is hard to start.
