I´ve reached the present! This actually happened on last Friday, I had another session at the garage doing some minor fixes.
The first and most important mission was to install this beauty that my multi talented welder friend made for me in order to get both a temperature probe and a pressure sensor into the fuel line:
Since the car was staying inside, I also took my time to insulate the wvo tank hoping that it will have a happier life in the winter. I just used a 8mm foam sheet made to sit on in the snow, but I´m hoping it will do me something good:
The last project I finished was to swap out my tail lights. I wanted darker tail lights as I´m planning for the car to become black, and at the same time I could do some modifications to the lighting setup and get rid of the extra turn signal lights added by the Norwegian dealer 20 years ago.
I ended up just ordering tail light housings from eBay and some bulb holders. The turn signal/reverse bulb holder fit the hole in the plastic perfectly, and then I did some minor plastic cutting with a Dremel to be able to add the tail/break light bulbs in the two upper holes:
Some of you might have read that I´m struggling with the new diesel fuel tank. Apparently, the previous owner of the tank had hydralic oil on it that he´d gotten hold of from a plastic fabric. Apparently the tank is full of plastic pellets that blocks my filters. sigh
I almost got home when the car died. Managed to drain the first diesel filter a bit and got home, where luckily my latest rock auto shipping had arrived with new pre filters. 15mins later, the car was good to go again!
At last, the sub back home with all 4 tail light bulbs live for the first time in its life! I´ll do more photos of the tail lights once I have some daylight again.
