Big T
Could you get in there with one of the new snake cameras?
You could, but you could also verify if the valley is wet. I found mine peering in with a bright flashight. It’s always one of the lines on the lower half of the clock face and it’s always due to the line not seating right. Ideally the lines should be attached to the IP first, followed by connecting to the injector, but we don’t always work that way.
