ak diesel driver
6.5 driver
Need to borrow my +2.00 readers
That would help, but, do I stackum on the glasses I already wear, or use just te readers ? LOLNeed to borrow my +2.00 readers![]()
YUP, new reman injectors, maybe five thousand miles ago. Did not checkum for balance though. Engine idles quite smooth, they must be relatively close.Yup, GM8. Move to a bigger turbo like the ATT or hx40 series along with a 4" exhaust and it will get you a couple mpg.
Heck, might open your eyes more on towing power and the bigger eyes help vision, right? Haha.
Seriously though, depending how old your injectors are (100,000 is when they wear bad) rebuilding them and making sure they are balanced to with 25 psi of each other helps in both power and mpg.
Not many things get both power and mpg increases, but those all fall under that list.
Nice work on the center caps. The ones on the Burb are rusted through the chrome so that's on the list of TTD but, very low priority. Re-Chrome or Powdercoat...decisions decisions.replaced the tails and boards. one had failed to cause the blinker to not work when the lights were on. thought it was the connection but it was the board. don't like the new design.
also received these:
will get the mounted soon.
Burb: LED #168 bulbs in the reading lights. 194s in the front Map lights. Barn door locking mechanism inspected and broken clip identified and repaired. Now to fix the plastic panel around the window...garage door closed on it...more than one piece now!
Paul, those plastic panels are a dime a dozen in SoCal wrecking yards. Don't bother fixing it, just get a replacement. If you are going to be down here for the Pomona drage races, I'll make a run to grab one and add that to the pile of stuff I have for you.
The PMD on the 2000 is mounted forwards of where You are mounting Yours, a bit higher too. Right under the radiator support cross member.Installed PMD plate on skid plate, but need more space between it and skid plate to accommodate Dtech PMD plus heat sink. Suggestions?
Also replaced a split tie rod boot with Energy Suspension Urethane boot.
