Will L.
Yes damaged cooler line can kill pressure and flow, engine killer scenario.  However highly unlikely- Cant imagine how you could pinch the line, but inspect to be sure.  If you did damage the line, replace them.  A  broken line will dump all oil in a matter of seconds and kill the engine.
I would really expect a pinched wire first. Bad ops- unless you smacked it with something, can't imagine how it would go bad during the chain swap.
If you didn't recover all of the chain pieces and one somehow pierced the pick up screen it could damage the pump, but you should have seen that when the pan was off. Also you could have knocked loose the pick up tube and it came free of the oil pump. Unfortunately removing the pan again is the only way to verify if this is the issue after checking oil pressure with mechanical gauge and still no pressure.
