Possibly, but I would think it would be hard to find a tube in that diameter with a reasonable wall thickness. Plus it looks like it's going to be a decreasing radius piece, so even a tube will need some adjusting. I don't think it's going to be too bad to make a piece that fills the gap, just gotta get to it. Probably Saturday.what about a pipe the right diameter and just use 1/4 of it?
Yeah the pics can be deceiving. I love the ideas though, keep 'em coming!ahh from looking at the pics it looked like a regular bend
Then bend one piece for each side for your compound curve corner, Hephaestus!Check.
Check.
Check.
That's the plan!Then bend one piece for each side for your compound curve corner, Hephaestus!
Forged In Fire! Quench temper those bends!That's the plan!
Hmmm, I wouldn't have thought to quench temper them. Why do that? I'm still learning metal forming. I'll probably do as much cold-forming as I can.Forged In Fire! Quench temper those bends!
Once you're sure of the bend being what you want, take the heat back up until it's beginning to turn from bluish to the start of a dull red and then quench the part in a large bucket of water. This will temper the metal and it will not only be hard, but will hold the shape of the bend indefinitely. Heck, you could even sharpen the leading edge of the bend and really slice through those corners!Hmmm, I wouldn't have thought to quench temper them. Why do that? I'm still learning metal forming. I'll probably do as much cold-forming as I can.
Gotcha. Ginsu bumper!!Once you're sure of the bend being what you want, take the heat back up until it's beginning to turn from bluish to the start of a dull red and then quench the part in a large bucket of water. This will temper the metal and it will not only be hard, but will hold the shape of the bend indefinitely. Heck, you could even sharpen the leading edge of the bend and really slice through those corners!
I hadn't thought of thick newspaper. Nice tip! Thanks!A simple job... rubber mallet & thick news paper on a curved object and 5 minutes, start with a larger piece of metal then lap it to the other part and then make your cut.... 10 minutes your done...![]()
I see what you're saying. Chrome would be durable too.....but my wallet isn't durable enough for chromeIn the one pic where you can see the front and side together it made me think it would look good if it were a shiny silver or chrome. Would tie it all together with the wheels and chrome edge of the running boards.
