@6.5TD.Club
If you go A-Team Turbo for better mileage keep me in mind for your OEM turbo.
The joy of the automatic transmission is that even on stock fuel you can spool a big turbo with relative ease.
With my 5 speeds with the wide 3-4 gap, on stock fuel settings I need to stay with the stock GM turbos.
As far as the thread topic:
I think I responded earlier in this thread, but probably way back when the fleet was 2wd only.
My best all time is 22.5 mpg out of my 91 6.2L NA half ton, but that poor little gal is winding 3 grand to do 70. Thank goodness for the Fluidampr.
For the 6.5Ls, the 95 GMC C2500HD 6.5L 5spd 2wd with 4.10s has hit the all time high for my 6.5Ls at 21.5 mpg on a trip from Indiana back to KS. Trip out it was pulling a U-haul, and it got 14.5 mpg with the cruise on and the a/c on, even through the up and down Missouri hills.
Formerly my, now dads, 99 Chevy C3500 chassis cab 6.5L 5spd 2wd 4.10s hit 18.5 mpg on an empty run with no trailer once from Idaho to Kansas.
All I can muster out of my 4wds is mid to upper teens the few times I have ran empty. My latest 95 GMC K2500HD I think needs front wheel bearings and brakes, hopefully that will boost mpgs.
Towing is where 95-98 percent of my 6.5Ls miles come from, and they all get from 10.5-12 mpg towing, sometimes the weight can exceed 20,000 lbs combination on long trips.
I would recommend talking to the many happy A-Team Turbo owners on this forum, they all experience some sort of MPG boost over the GM turbo, how much was variable on the vehicle specs and the driver. I think the average is 1-3 mpg increase, with as low as .5 increase to as high as 4 mpg increase mentioned.
