n8in8or
It's finally time to make a box to enclose my air filter. In previous threads I have installed a CKO HX40, relocated the battery and installed a big air filter.....so everything I'm doing here is one-off for my application.
The first thing I did was do some wrapping of the AC line and accumulator, this was for 2 reasons: 1. I thought the AC line would be running through my intake box so I didn't want the added heat in my intake tract and 2. while I was at it I figured I might as well wrap the accumulator to keep turbo heat out of my AC system. Wrapping the line in insulation all the way to the firewall would also help this.
The next thing I did that seemed kind of related just because it should hopefully keep a little heat out of the engine bay was to put a turbo blanket on finally. I contacted the seller on Ebay to ask them if the one they had listed would fit on my HX40 with the wastegate actuator...he said it would fit ok, but that he had one for an HX35 that would be a snug fit, but work with the actuator. So that's the one I bought. I really like the way it fits and the gray goes well with my color scheme
Then I had to reroute the intake tract itself. I didn't figure I'd be able to make a box around the existing setup with its weird angle, so I made a plan to make the filter fit 90* to the turbo. I found a 4" plastic elbow by AirRaid that would fit nicely in the filter, then I got 2 4" silicone hump connectors to finish the connection. The hump connectors would allow some flexibility since it wasn't going to be a perfectly straight shot and it would reduce vibration transmission down the intake tract to the fender (which I've already struggled with). The connections worked as well as I hoped and what I really like now is that I don't have any metal in the tract to easily conduct heat into the intake air.
