hookedup50
whats the app?
IIRC, read a report of a Burb (GMT400 body) that got 27 mpg highway (while using A/C) by switching the fan over to an electric from an Olds. If you are not going to tow, the Flex-A-Lite looks like a good solution.
I got ya all beat: 7 MPG towing.I don't think it's possible to go lower while moving. (A gas engine is cheaper to operate towing even at it's 6 MPG vs. a stock 6.5.)
Then after improvements gained 3.4 MPG and like 25MPH towing. ATT, 4" exhaust, Walbro lift pump, snorkel removal.
Best at freeway speeds was the suburban with the ATT and spool valve getting ~16 MPG at high CA freeway speeds - an improvement over 14 MPG. Round town I get 10 MPG.
The 2003 Dodge 5.9 with the MT is 20 MPG mixed with a big hit to 16 MPG AC on. It goes over 20 MPG freeway. ~15 MPG towing.
Keep in mind LSD and ULSD is lower BTU diesel than the fuel of the past. So MPG you recall from the past is no longer possible on today's fuel. Biodiesel (B99) also reduces MPG by 10% due to less BTU.
I am going to call BS on that one.
vssb off by a little? Hope not, hope he really got that.
Have a guy a work that always comments on how great his old 82 6.2. Swears he was close to 30 on some runs. Really great for him as he was making his own fuel way back when.
