devildogadam
Active Member
We liked to do runs with sledge hammers and tanker bars. Then stop when someone falls out and do some for of work out until they caught up.... then just keep running until it happened again. It was always fun
Going to do injector soon I'm not even sure my fuel gauge works because 7 gals shouldn't be half a tank if the tank is 34 gallons.Bdemutis a lot can depend on the right foot... and if your chasing down problems with the turbo among other things all will add up to poor fuel economy even if the engine seems to be running smooth. A big one would be those wore out injectors. Replace them with some STOCK bosh injectors and your sure to gain some mpg. Lift kit will never help mpg. But I sure you can squeeze some better mileage out of her if you do some much needed maintenance.
I will when it warms up I don't want to drop the tank in a freezing pole barn. I'm waiting for it to get a little warmer for injectors also. I don't see it on leroys website.Likely the fuel lever sensor doesn't work. Get a modern bombproof one from Leroy.
On the subject of MPG, how much does adding cetane improvers, improve mileage at all. . . . Anyone with thought or real world data.
On the subject of MPG, how much does adding cetane improvers, improve mileage at all. I loked online and found almost nothing that wasn't company sponsered. It is hard to know what you are even buying at the pump as ratings are not required. I called gulf /cumberland farms and they admitted 40 or the minimum. The few Hess stations state 43 cetane. When I get fuel at sunoco I pay more for fuel, but get almost 2mpg improvement on winter blend. But probably not worth the extra money. If this is hijacking thread I will make new thread, but it seems to me cetane has an effect on mileage as mine is all over the place depending on fill up location. Anyone with thought or real world data.
