malibu795
misspleelleer..........
got the 2886 clutch and dmax fan,(moves ALOT more air at idle tell tale is miny dust clouds from then dirt lot while backin up) install flowmaster cross over pipe also heat wrapped the pipe down pipe is next. air filter changed. got then fittings and hose pressue guage for FTB mod.. can this be done with out removing the intake?
took it for a test haul/tow. my 75k20 roughly 6000lb and my brothers load max 20+5 gn ~4500lb. tottal of 10-11k trailer weight ran nicely...
get to sort out electrical problems.. mainly with the rear lights and wireing harnes and brake control harness replaces then batteries today as well. found out then diff is leaking at then pinion seal too:nonod:
