btfarm
America First!
I suspect you may find that your voltage drop may change when you install the new cables from Bruce.
They're AWESOME!!!....Night and Day Difference.....Worth EVERY penny!
JMHO
i am waiting for these to show up and get installed before i go into the electrical more then i already have
I hope you got the "Glow Plug Harness" as well..........The craftsmanship and materials are 2nd to NONE!
4000/6600/15700 total 264000 rounded to the nearest 100lb truck is 13800lb,
actual wieght per cat scale ticket.. since i couldnt remember when i posted.So the truck is running just a wee bit over spec......If I'm understanding this whole GCVW......The GVWR for the 3500HD is 15,000 LBS..........and your at 15,700?
Or is it actually under GVWR at 13,800?
drive axle 66400lb
Extra zero?
