FWIW the grounding of a Heath unit does not happen through the mounting bolts, gnd for it is strictly through the harness itself.
My 1st one started it's life 3 years mounted to the plastic license plate holder it's almost 7 years old before I relocated it inside my Buckstop bumper, 2nd one on burb going into year 5 also mounted on the plastic plate holder on front bumper.
Fail rate published or unpublished has been relatively low or we would hear of more of them.
Some may remember the RemarQ "improved & redesigned" units when they started failing like the flight systems ones apparently are starting to happen the word went out like wildfire, if the fail rate of the Heath units were high as some are indicating may be happening.
I'm confident the aggravation & cost would make it to mainstream on web "I paid big $ for this and it doesn't last any longer than the rest of em", the 6.5 crowd as frugal as it is would get that word out fast, I doubt a conscious effort to keep that information from getting out. Every forum that has a 6.5 discussion #1 topic is PMD related and if a bunch of bad ones from Heath were out there it would come out yet the opposite seems to be the norm, bad driver replaced with a Heath and have not had a problem in X years.
Apparently what he is doing is working, while some choose to not believe the test I ran years ago, and the data sampling where located & how long it lasted in that location, and what setup, those results did in fact show the Heath to have the best longevity of all tested then.
Heat is a factor whether it be the failure of components, or the cyclic extremes mechanically causing fails of connections/components, the problems of temperature have not escaped Stanadyne or Flight systems as both openly advertise their redesigns to be more heat tolerant, if heat wasn't a component of fails why make mention of it?
To the postulation of ones that are mounted on trucks that don't have much ambient condition changes lasting longer than those that do have many swings through the year ??? Possibly
But consider Ellensburg, Wa. where they are made have many ambient changes, as do places like Canada where they run successfully, in my own vehicle testing where temps in summer are very high and temps can get single digit and vehicle has been in upper US Great Lakes winters the Heath has survived all these years. Only fails on my truck I have ever had have been IP mounted, intake mounted, driver side fender mounted just aft of battery, since mounting out of bay on Heath remote 0 fails 2 vehicles is success in my book.
Why did Stanadyne wait so long to fess up???? Liability plain & simple, it would have cost GM & Stanadyne far too much to campaign replace all of them rather than via attrition when/if they happen. As it was also documented in survey I did that some drivers lasted life of the trucks at that time a couple in 300K mile range mounted on the IP and were still operational.
Will Heath's failure rate go up with the new drivers when sources of black ones dry up? Possibly ? Kind of neat though that his KISS setup works so well and defies logic & calculations of those that have tried to debunk it over the years.
Kenny my friend I don't know what dark cloud follows you or what you did to piss off the FSD gods or gearhead gods in general (you should have never gone to Lee's Auto Ranch) you haven't escaped the cloud since then maybe you need to shift to a bicycle
no then we'd be hearing about flat tires & where to get the best run-flat tires
Anybody know of a good exorcist to swing by Kenny's place, with a truckload of holy-water ?
