It was while merging on the highway, not to long maybe 1-2 minutes.
What temps have you seen towing?
My intake temps settled to around 195-205 on the rest of the way home, downhill they dropped to 155 but climb back to around 200 for the most part.
Boost was 14-15lbs, ambient temp was around 85 or a bit hotter. Towing weight 10500lbs, cat on a GN trailer.
Not calling you a liar, but that seems kinda light for a cat(unless feline) and a GN trailer. Figured it would weigh more unless its a tiny dozer and a light trailer.
Tim, What IAT do you see with no intercooler? I did my 1st hot temp tow today and truck is running hot, IAT were over 260 degrees and coolant temps were over 210. I have an issue with my fan, clutch didn't engage at all today while towing. I am going to do a rad clean and cooler cleanse and add wetter water but the intake temps aren't helping.
Joey, I don't remember, but does your truck have a bodylift as well as suspension ? Plus don't forget Joey's truck is turnin some big tires. That adds alot of strain(I love that straight axle conversion).
You callin me a liar):h
Big cat skid steer on my GN trailer.
Skid stter weighs just under 8000lbs
trailer weighs under 3000lbs, could be just under
Total weight under 11,000lbs so I may have been a little off but not much
RPM's were around 2100-2200 in OD. Power was down as well which I suspect the ecm was defueling.
I will do the rad clean this week with the coolant flush, new stats as well, and new fan clutch.
My cooling system is all factory except for 2 flushes and 1 rad clean out a long time ago.
I will do GM stats and a new sensor in the head as well.
Ace, I have the 4 bolt fan hub. Thanks for the offer though.
Bend the tab out 1/8th inch or so as the DIY Fan clutch mod thread indicates. See if it helps before buying new.
Hey Tim, You have a get out of jail free card or what? You go 111 mph everywhere![]()
