I looked into this a few years ago. In theory it sounds great. I called and spoke with one of the technicians at Evans. He was very polite and knowledgeable, but I did ask him some questions that he absolutely was unable to answer.
For example, Evans claims to have a really really high boiling point such that one can keep the cooling system at a very low pressure and allow the temp gauge to skyrocket and 'not worry about overheating'.
However, we have learned to rely on the coolant temp gauge to know when things are getting out of control. There is a measurement method, tried and true, where we know when things are OK, or in danger.
When switching to Evans, my understanding is that there really isn't any way to tell if things are working (other than your block isn't fried, and you're not stuck on the side of the road having turned your mighty 6.5 into a puddle of unobtanium). That's right - the temp will go way way up, and you are not supposed to worry. Well, what if you have a loss of coolant due to a leak? What if you are really low on coolant and the temp is spiking? Wouldn't you be roasting your engine?
It may well be that I misunderstood the answers, but that's what I came away with.
They did say that you need to upgrade to a high output water pump, and the dual stats, IIRC. No worries, that's straightforward to do. However, draining all the liquid from the 6.5 IS a problematic issue. No good way to get to the block drains without some major work - my understanding is that they are in the region of the engine mounts. You have to drain ALL the water out, or the Evans won't work properly.
-Rob
