Would it be one like the SEALED POWER Part # 22443621 I find at Rockauto and which is a 1997 HO oil pump made by Melling?
In fact, did you re-use the one which came with the Ted's engine or did you swap it?
I have 75lbs cold idling, and 55lbs hot idling now...
Well, my thoughts were.. you're crank - rods - cam all float in a thin layer of oil and the more oil pressure the less chance of galling or spun bearings.
My experiences of running HV / HP pumps have never lead to running out of oil in the lower end (in old 350's - 400's) but the only reason there ever was engine failure was from over revving, stretching rods - floating valves for long periods... stuff like that.
I've twisted bone stock 350's to 7,400 RPM's and 400's to maybe 6,500.. with hv /hp pumps and never spun a bearing.. the carnage came from other areas.
Not trying to argue with anybody or steer anybody in the wrong direction.. just my theories and experiences.
Mike
