n8in8or
TYPO ALERT! I was rushing to get this posted since my lunch was ending and I totally screwed this up. Let’s try again. The .2679 sq in is correct, but past there the numbers are wrong. This actually works out to a RADIUS of .292”, which of course works out to an INSIDE DIAMETER of .584” or a little over 9/16”! So maybe the current suction tube is a bigger problem than originally thought?I should also see what the Raptor 100 should need for a suction line. I'll use the 100 gph figure of course, and also the desired 2 cfm based on me driving in a cold climate.
So 100 gph = 1.67 gpm
(1.67 gpm x .3208)/2 cfm = .2679 sq in.......that works out to a RADIUS of .3747, so that means the ideal suction tube at those criteria would have an INSIDE DIAMETER of .292" or a little under 5/16" ID. So the existing 3/8" tube is ok currently.....except that I know if necks down to a much smaller size at the factory o-ring seal. I don't know if it's really impeding pump performance right now, but it certainly isn't helping. That's interesting stuff.
