treegump
Romans 3:22-24
IF you put a mechanical wastegate, ie turbomaster, your black smoke should go away I would think.
thanks - but i like the black smoke
Recommendations are 100k miles, most have gone longer. Vendors here have them or there's ebay. Stay away from anything that isn't Bosch, AC Delco or Stanadyne.
Delphi is another good injector. Dieselpro from the Place recommends them.
Yes except for the selenoid. I believe you need to leave it plugged in until you chip it.
no on edit I saw the pics of your engine in another thread and you have an s engine at least it looks like an egr hat on your intake. Do you have 2-3 selenoids side by side on the drivers side valve cover close to the firewall? If so you'll have to leave it all in place for the vacuum to the egr.
so...i guess my question would be - is there anything back in that corner that is known to leak, and how difficult is it to fix the problem?
