Ama83
What would it be, it mostly can be heard at 1500-2000 rpm´s accel and deaccel also :???:
Could it be the AC pump?
It should come on with the defroster
Do you have a boost gauge? I see you have a turbomaster, but do you see any correlation between the loss of power and boost pressure?
Just an idea, but maybe it will help in narrowing it down...
The next time you get the noise, pull over and put the truck in neutral and rev up the engine. I'm absolutely not an expert, but I would think this should at least tell you if it's drivetrain related or engine related.
Do you have a mechanics stethoscope (or a really long handled screwdriver... put your ear on the end of the handle)? Maybe try poking around with that and "see what you hear"?
How long can one safely run the engine without the belt on? Maybe the next time you hear it at idle, take the belt off and see if you still hear it? DON'T do this before we find out how long it can be done safely. Just trying to think of things to do to help narrow it down.
fan clutch should have some resistance even cold.
