dka99burb
I have the intake off getting ready to replace the IP. I am only able to work on it a little bit about every other day so I have time to do mods while it's apart. I don't want to have to pull it any time soon so what else should I do while working on it? Here is my current plan as I complete this task. What do yall think?
1. Install Leroy's OPS relocator
2. Install two 12T1E thermostats
3. Do something about replacing that crappy quick disconnect heater hose. Thinking brass barb and straight hose. Any suggestions?
4. Pull Turbo off and replace leaky drain tube. I don't know where or why it is leaking but it is and it is hard to see. What is best way to get to it?
5. Tap fuel line for pressure gauge sending unit while I have access. Any recommendations on where to tap and what to use?
6. Finish up with installing my gauges: fuel pressure, boost (boost bolt), trans temp. Plan to purchase EGT in near future.
7. Thought about removing vac pump and installing a turbo master but the vac system is working right now.
8. Do I have to get the hose that goes from the water pump to the thermostat housing from the dealer? I think mine was original. I had to cut it!:rolleyes5:
