That mechanical eraser thing would also work for that but it might take a LOT of them wheels.I was referring to the molding strip that goes along the lower doors, not decal removal.
I’ll let you know what works. Probably a version of what I described earlier. Pry up a corner to get a lifting point to pull it off. Except, instead of a thin razor blade, I’ll use a hard plastic putty knife. Will try to remove remaining adhesive with Glue-Be-Gone type stuff and move on to lacquer thinner/acetone if that proves ineffective. I’m repainting so not too worried about damage to the paint. I’ll use the ’eraser’ wheel on the thinner remaining residue.I was referring to the molding strip that goes along the lower doors, not decal removal.
That's not new. Just a different product. I saw gray several years agoI think I dont like this new “ Right Stuff “ gasket adhesive sealer.
It now is grey in color and is almost as thin as Honda Bond adhesive.
I started out with the old dispenser container of black right stuff. It run out.
Went to the parts store to get another container, the jug was larger in size, well thats okay. Got home, started squirting some on the rocker covers and it dont match in color. Flowed out with a thinner consistency as the old black stuff.
Guess it should seal okay, I just warnt expecting such a change is all.
When I bought the container that I just finished, there was but only one Right Stuff, black and thick.Yes there are several different versions of it. It pays to read the label
Reminds me of John Deere giving the same name to different products.When I bought the container that I just finished, there was but only one Right Stuff, black and thick.![]()
YUPReminds me of John Deere giving the same name to different products.
There's at least 4 different John Deere 400's
Use a heat gun to loosen the glue first...I’ll let you know what works. Probably a version of what I described earlier. Pry up a corner to get a lifting point to pull it off. Except, instead of a thin razor blade, I’ll use a hard plastic putty knife. Will try to remove remaining adhesive with Glue-Be-Gone type stuff and move on to lacquer thinner/acetone if that proves ineffective. I’m repainting so not too worried about damage to the paint. I’ll use the ’eraser’ wheel on the thinner remaining residue.
Finally got the remaining gasket, carburetor and fuel tank to finish this and it starts first pull. Not bad for $50 in parts for something I was ready to toss in the trash. When I felt it still had good compression, I knew it was salvageable.Not a GMT-400, but an Echo SRM-2400 1E. Replacing the oil seals on the crankshaft, a number of gaskets, carburetor and a new fuel tank. Unfortunately, work is stalled as I wait for some of the gaskets.
I split the case halves after these pics and cleaned the hell out of everything including that caked on grease in the clutch housing in the background. Everything was fresh and minty before I put the case halves back together and installed the oil seals. So I am stalled at installing the cylinder/head as I need that base gasket.
View attachment 81465View attachment 81466
Well this did not solve all of my oil leak problem. Looks like I’m getting some oil leakage from above the VTEC solenoid valve, which points to the valve cover leaking. Ordered a new OEM valve cover gasket and I will redo that.Replaced the leaking VTEC Solenoid on my Honda Accord. Had to remove the exhaust header to create access/room. Had to cut the rounded head off one bolt. Applied Honda Bond sealant around the outside of the oil seal. I’m going Marty on this one.
View attachment 81682View attachment 81683
I could ride the
Those were the good 'ole days!Looking at his front fender sponsor logos, Western Auto is no more.
