Left side enjun mounting is out. Vice grips on top side bolt head and loooong extension with wobbly socket on the bottom side. Popped them right out, the lower bolt, ratcheting 15mm end wrench on bolt head and 15 mm open end on nut. A bit of a bear but they is now out.
Left side clam shell slid right out of the hole for some reason. Right side had to be totally dismantled and then it still took some twisting and forcing. It really helps to remove that bell housing to engine mount strut rod ad drop that inner plate out of the way until the clam shell is into the upper engine mount.
Left side worse than the right.
Marty, let me know how the motor feels and any idle vibrations in the floor or pedals after you get done. I had replaced my mounts and had a foot massage action going on for a while. It's seemed to have subsided not, but unsure if that's due to the summer weather and the rubber has softened or they finally have broken in!
When I had pulled the nuts on the through bolts during disassembly, the through bolts could not be pulled by hand. Had to use a hammer and a punch and drive them out. The right side was a real bear.
After installing the new mounts, them through bolts pushed right through, almost no resistance at all.
I sure will. I was also wondering how many rattles and squeaks these new mounts is going to eliminate. 😹😹😹
I took my new/old stock cables over to the NAPA store. I had all the cables cut to length and used pull strap zip ties to hold it all together so the cables would be in their perspective positions.
The parts person most familiar with making up cables was put to the task. Stripped the insulation from the main big cable that would have gone to the starter. Corrosion, all the way through.
Well crap, this aint going to do. We discussed it and I priced their cable by the foot. The larger size 0 i think its called, was $6.00 a foot. Okay, 3-1/2 feet of that. Okay, that aint so bad, the smaller diameter cable, same size GM used on the side terminals was like $3.00 a foot and I think it was about 8 foot of that.
He set about soldering top post terminals to the wires and included a 10 gauge pigtail for a fusible link to the alternator.
I wanted the terminal that hooks to the starter to have that positioning lug that keeps it from turning and rotating around to the solenoid terminal. The store does not carry such a starter terminal. Clipped the old starter wire and used a wire coupler sleeve to splice it to the new harness.
If anyone is thinking about making up their own cables it might be a good idea to see if those starter specific terminals are available someplace online and get those before attempting the build, or, do just like we did and splice the old terminal to the new harness. It will be perfectly fine as the wires of the old cable were bright and fresh looking. The coupling aas then heat shrink protected with the heavy gauge heat shrink made for battery cables, as well as all of the other terminals.
The negative top post cables was easy, stock cables from off the shelf.
Now the positive cables are all red and the negative cables are all black.
All told the price tag came to $138.00.
That cable heading towards the firewall, that one feeds the relay/fuse box and uses a terminal with a 1/4” hole in it. That is a lot heavier cable than what the factory cable had running back there.
I guess now, I will take all of that new old stock battery cable that I have, split the insulation, peel it off and drop it into the copper wire bucket to be sold for scrap.
Melt down the lead post lugs and make them into bullets and stinkers, oooops, sinkers. 🐈💨 😹😹😹
That all looks good! I bet she cranks over a lot better now! although I would go with a larger cable than 10 gauge for the alternator. I added a 4 gauge to mine piggybacking the factory one and ran it to the relay box so it's feeding the batteries and the fuses. you could run a separate cable off the side post terminal to the alternator, add one of those 100 amp resetable breakers on it rather than a fuseable link. that way if it ever trips you can just reset it and be on down the road.
I will look into that 100 amp resettable breaker.
On one other comment about changing enjine mounts.
Have one of those gear wrench 15 mm ratcheting end wrenches in your tool box before starting this job., it is most valuable.
Here's one. They also list 120A, 150A and 200A 12VDC circuit breakers, too, @MrMarty51.
Here's the whole page of breakers they have, both AC and DC, @MrMarty51.
I will get one a coming. Thank You very much for the link.
Should a person go higher than a 100 amp, wellp, maybe answer my own question. Alternator is capable of at least 100 amp so probably a 150 amp would be better. 🤷‍♂️😹😹😹
Not doing a thing today. Just the usual and kicking back.
If the truck is not completed before the back surgery towards the end of the month, then that is just okay. It can wait until I am healed and by then that nice CB will be here and I wont be doing extra wire changes to the alternator.
you could utilize one of the auxillary maxi fuses in the box under the hood for this. those two extra studs on the back side are for those two fuse blanks. I used one of them with the extra 4 gauge wire I added on the back of my alternator.
