Big T
Swapping an IP is not too bad. Pull the upper and lower intakes. The hardest part is getting to the lower injector lines on the back of the pump. (need a 3/4 inch crows foot). Take the oil fill neck off and you can get to the three bolts that hold the gear to the pump (just don't drop them down in the engine and you won't have to take the front cover off) The gear will sit in place when you remove the pump and there is an indexing pin so the new pump will only go on one way. If you get the timing close by ear and then the pump can adjust itself to the exact timing.
I'm down to the 3 bolts that hold the gear to the pump. Oil fill neck is off and I don't see them. Do I need to spin the engine to get them to appear in the oil filler neck hole?
