Here are some more tips...
To get up:
1. Pull your knees to your chest.
2. Wrap your arms around your knees.
3. Let the boat do the work. You should not have to work to get up.
4. Depends on what kind of boat, but you should not have to go to WOT to get up. A good driver helps greatly on getting up. Try to find someone that knows what they are doing.
5. After the boat starts wait a couple of seconds before you try to stand. Men are the hardest to teach because they want to stand up immediatly. You got to get some water pressure built up first.
6. Don't let go with your back hand, See # 1 Below. Pull the rope to the hip that will be in front. (General rule: Kick a ball with your right foot, left foot goes forward and vice versa)
Staying up.
1. Keep your arms straight. DO NOT PULL ON THE ROPE! If you pull on the rope, you can not make small adjustments required to keep your balance.
2. Both palms should be facing down. Put a small amount of pressure on your plams so that the pull from the rope is coming from your center of gravity (hips).
3. Bend your knees slightly to absorb boat wakes etc.
4. It is likely that you will take off over the left wake (port). Go with it until you figure things out.
5. Relax. Overcorrecting is the biggest mistake I see.
:cheers2: and welcome to a highly addictive sport!
Boating etiquitte:
1. When a rider falls do not do a power turn. Take the boat to idle and turn within your wake. This will lessen the impact of your wake on yourself and others and it is safer to get back around to the fallen rider.
2. Drive a straight line. Again is safer, will minimize the wake on others, and will result in a better pull for the rider.
