guybb3
IIRC they go into a cast bracket that holds the alt. not into the block.
I was thinking the same thing, but didn't want to mislead or open the hood, so I didn't respond.
Thanks guys. Exactly what I was hoping to hear.
They are not blind. You can see them at different angles while looking in. Just remember they are behind the pulley.
I am getting ready to remove the vacuum pump however when I searched the technical library and previous posts I can't find anything on how to. I can see 2 bolt between the alternator pulley and the Vac pump pulley. Anyone have any how to info?
Thanks!
There should have been a hole in the pulley you could insert a socket on an extension to reach the bolt head. Rotate pulley to align hole with bolts.
DOHHH! Two or three holes in fact... Now I remember using the pulley remover/installer on the vacuum pump, already off the engine, on top of a 55-gal drum. Thanks for bringing back the memories!
Regards,
Franko
So, are we just removing the pulley, not the whole vacuum pump?
Mine 94 had two bolts accessible from the front and one bolt accessible from the back turning a short job into a standard struggle. I ended up eliminating the mounting bracket as well. It held nothing else and improved passenger side access.
Took mine off today, piece of cake thanks to the info here, wouldn't have figured it out myself. With the belt off moved the pulley around until the hole lined up with each bolt, could see them with a flashlight. Close call with the fanblades so close, but I managed to not scrape off any skin. I was going to get a 99.5 and a 100, but Advance Auto only had a 100. It fit well IMO, was a tight enough fit that I don't think I would have wanted to try to force a 99.5 on there. Was only about a 5-10 minute job. Couple minutes trying to figure out if the pump would actually come out of there without removing stuff. Eventually got it out by pushing cooling hoses and lines aside and rotating the pump every which way while pulling up gently.
I removed my vacuum pump today and it took a 101 & 5/8 inch belt. I started with a 99 & 1/2 and it wasn't even close, next I tried a 100 & 5/8 and it was close but wouldn't go on. The next stop was the 101 & 5/8.
As for pump removal I had to take the bracket off to get to the 10MM bolts from the back side.
Belts now also seem to stretch more than they used to in days gone past, when I did 1" shorter 100" from 101" belt was midrange of the tensioner, a week later it was loose & squealing so bad I thought I had lost an alternator bearing indication of tensioner wear window at max wear position.
Now using 99.5" with the the tensioner barred fully over full travel, there is just enough slack in tensioner to tight slip onto the accessory & drive pulleys (better with (2) folks replacing the belt), but now the same week of use now puts the belt in midrange of the tensioner wear scale, and this has been with several different mfrs of belt I've tried.
