Well i got it all hooked up boost controller and boost gauge and also a new gasket for the intake tube but......flooring it im getting 5psi i can hear the turbo spooling and i have the spring really tight, there was 2 bolts on the intake tube that wouldnt tightin but all the other bolts are fine and the intake tube is on there good with a new gasket and im still getting 5 psi what the hell?
My 98 will spike anywhere from 5 to 10/11 psi on the stock gm8 and vacuum control and 0.2-2.0 on steady cruise.
Keep in mind, these are high compression diesels from the factory, designed to use low mounts of boost.
You are not going to get much more than the 5-8 psi quoted into them without paying for it somewhere (IE: high heat or maybe - BOOM!)
Is your X over pipe leaking....Or any exhaust leaks?
previous ownermight have removed the tstat because of over heating issues
