wildamericatradingco.com
it will, but the string will be a tire's width away from the front. it's just having equal measurements making a visual straight line on both sides of the truck. I mean if you want to go to the trouble of removing one wheel from each side of the rear, you can. but it's just to give you a better visual instead of just eyeballing it all. getting the string straight with the truck does take some time to do using the rear tires as a reference point. One thing to note. this won't work when the wind is blowing. it won't take much of a side wind to make the string move.That will work even though it's a dually??
