Big T
Said several times, none of these u-joints are greasable. They have needle bearings and no grease fittings. Apparently the one that failed is a Borgeson u-joint made in USA. The Difference: old one they welded the u-joint to the steering shaft. New one has the u-joint sliding over the steering shaft and is held in place by locked set screws. Steering shaft on new Borgeson is much thicker metal.So the ujoint failed, not the shaft. Ok.
Yes- normally a ujoint not getting lubed there would run for half dozen years before giving up in steering shafts. Unjoint manufacturer most likely had a assembly line error in bearing production or something.
Like when sealed ujoints fail in pickups during warranty period- it happens but usually in a batch from bad needle bearings.
Can you see the new one? Is a brand of that ujoint visible? Is it greaseable? Too bad the first one wasn’t- I’m sure it would have made it longer than the truck.
