WW, link not working.
For the benefit of the readers. Lets put this into perspective.
Phoenix, AZ is 1,117 Feet in elevation. (340M)
Payson, AZ is 4,921 Feet in elevation. (1,500M)
My old route continued on past "The Rim" at 7,000 feet. (2133M) This area between Payson and the rim is where the scuffed and cracked piston burned through. It is also where we bagged our Elk (and the GMC truck).
The hill I am thinking of takes a couple good climbs to get there. I recall it is a 10% grade for at least 6 miles.
Shown here:
http://www.aaroads.com/west/arizona087/az-087_n_seq_229_climb.jpg
My leg gets tired holding WOT after the cruise control kicks out at 16 MPH below the set point. Wedging an umbrella between the seat and floored throttle will not exceeded the speed limit towing.
The above is one of many brutal climbs along the route we had that ended (turned around) in Springerville.
Sarcasm Alert
:joke: Try flying....
:reporter: News Flash, Phoenix AZ, having only recently paved its streets, found the money to build an airport that will accept large airplanes. Flights arrive daily and they have hired extra cowboys to keep the livestock from wandering on to the runway. Even the Indians are cooperating and have ceased shooting arrows at passing aircraft.
^^^lol! have you guys contacted any of the diesel magazines? i know they are usually looking for 6.5 stuff and Ian supposedly had an article going for something like this or maybe it was a pcm comparison
I have a killer mountain grade with killer temps we can use. It is the 10% grade to Payson, AZ that goes on for better than a mile with lots of good grades in between here and the hill. I have sent a couple 6.5's to the scrapyard attempting to make this climb.
None of the wimpy Heath area hills. :hihi: Even more hazard is the Elk in the area - not 'love tap' deers.
What date works best for a get together on this? I have open weekends Friday through Sunday. Weekend of Oct 22, Oct 29th, or push into November? Please post up dates you guys like!
The 22nd is almost out as I am still recovering from bad fuel and do not know what else was ruined by it.
We are in the "cool" weather now up there, but, this is the weather I have a good baseline from the 1993.
its kind of a moot point anyways, unless someone is going to buy and supply you guys with a CKO-40 (chinese knock-off hx-40) to test against the ATT and gmx turbos.... i dont think "the zombie" is going to show or communicate in this thread as i have heard he is banned from the site... and it is unlikely that slim or TD are going to buy one to have on hand....
I'm headed out of town on my dime this month so Veteran's Day weekend, 11-13 November, works best for me.
I may have my friend's toy hauler to bring down. Will have to clear it with him as he's using it for temp storage while he house hunts.
I do have a GM-5 on the truck and an ATT in the box available for use if needs be.
Paul, is that the best turbo to run a test with when trying to make a comparison, if I remember correctly that is the one that came off of Ted635's truck that Ian cobbed up the installation that had to be repaired shortly before he "voluntarily left" employment from Bills place to seek other career path.
Some of the repair required minor compressor & turbine wheel blending, not enough to make it unserviceable, but possibly enough from what was recently discovered in last batch of turbos that have caused an issue on a few trucks that clearance changes are netting less performance than what initial turbos are netting.
We're looking at Thursday or Friday at being in your area. PM SentAlas Paul I'm working nights out of town next week, though you are going near by where I am working, 19:00 to 07:00 is my shift so depending what time of day you'll be coming thru the area we may be able to hook up. We'll give you a call when we're more certain of ETA's. Perhaps in the afternoon after you've had a some sleep?
Dennis & I discussed the housing swap plan good idea IMO, highest altititude on mine thus far has been 3100' towing a 8x12 enclosed trailer loaded to about 3000# at Fancy Gap Pass http://www.roadstothefuture.com/I77_VA_Fancy_Gap_Photos.html not many big pulls East of the MS but a good workout for a 6.5, Dennis moved a couple of tractors MI to NC that same pass a few years back about 31K combined weight IIRC.
No smoke on mine nor Dennis, and this was before the ATT dedicated tunes we are running, Bill & I discussed a mpg tune from him for mine then on 2nd thought possibly after seeing running ATT with yours decided to not go there just yet with mine as he had some other ideas to with the tune keeping performance-low smoke & mpg kind of hard to fit all 3 into same blend for the tune but I'm patient.
I run for most part 70-75 mph no smoke there either except for a healthy puff when I go WOT. Healthy Puff would be understandable, I get that with the GM-5, ATT is a little more productive
Good luck on the Ga visit I hope you get that issue resolved, tough dealing far away from a vendor especially when they become "silent",That is the frustrating point
I'm hoping to be out of here by end of next week, possibly we can get together on the return trip and I can have you run the video camera while I make some runs. I'll be bringing some photo gear so I'll throw in the GoPro camera I picked up. I would enjoy a ride in your rig. Unfortunately I won't be able to return the favor as we're scrimping and for the MPG, taking the Passat. At least we'll effectively double the MPG and see improvements in RT=D
While the altitude you operate at is higher than mine, there are also other ATT operators of ATT your side of the divide pulling without smoke, when you get back I'd like to see if we can nail this down to have a clear idea of the combination of factors that make a few vehicles more prone to smoke vs experiences thus far on the majority of the population of users that don't smoke, we can talk more though when you get over this way hopefully. I need to do a compression check for peace of mind too. I'm still wondering what the "cost" might have been for that abstract "oil on sheet-rock" art deco job I did on the garage wall and if that might have a play in things
