kmccoy
- Messages
- 22
- Reaction score
- 62
I have a 2003 Chevy Silverado 2500 HD Duramax 6.6 with a 5 speed Allison transmission, 130,000 miles. I’ve been fighting this problem for months. Three months ago I drove the mentioned vehicle for about two hours and parked it in the driveway like I always do everyday. The truck runs and drives great. I had to have injectors replace in 2017 and installed an air dog lift pump. Been running great. The truck sat for two weeks, it started up normally and ran fine. I let it warm up for 10 - 15 minutes. When I got back in the Trans temp gauge was pegged, the buzzer was dinging and Transmission overheat Idle engine appeared in the instrument cluster. The fluid was at normal level and a little dirty but not horrible. The trans cooler and transmission pan were warm to the touch in no way was the transmission overheated. The vehicle sat over night. Turned the key to on, gauge pegged into the red and got the same message on the dash. I don’t have to even run the truck.
I did some research and upon checking I found trans fluid in the connector at the back of the transmission. I’ve replaced the transmission internal wiring harness, the internal and external transmission filters and replace the fluid. Same problem, same symptoms. If I drive the truck it runs fine but it shifts erotically. I inspected the wiring and connectors to the Transmission Control Module (TCM) found nothing. I sent the TCM in to be checked and repaired but they forums nothing wrong with it, sheared the codes, programmed it and returned it to me. I installed it today. Same problem and symptoms. Drove the same as well. Trouble codes P0218, P0736, P0736,P0741, P0836 and U1096. Im thinking the last 4 or 5 codes are from test driving the truck.
Any suggestions?
Any suggestions?
