Quite frankly the shortblock is the least of my concerns. :skep: Optimizer or 1986 6.2 does not matter to me. I have enough other problems that the shortblock has not caused me problems.
Every 6.5 engine I have sent to the scrapyard (3) had something else cause it's demise. Bad fan clutch and 6 blade fan overheated it and scuffed a piston. Bad injector melted the #8 piston down. Plain old wear took out the rings and bearings - block was good, had been rebuilt before, except for a fixable head bolthole crack. Only 1 of the blocks had mains cracks bad enough to say it could have failed soon and it had 177K on it.
I tow hard 10% grades and heavy at max GVWR of truck in extreme temperatures 115+ about every week day. I have bent the hitch with loads that were too heavy and not balanced right. I have turned up the pump and turbo to get the most out of the surplus 6.2 engine and have 30K miles doing so. This is 2750 miles towing a week!
AKA I put more than factory stress on the block especially for a N/A 6.2 and I hold the throttle to the floor for extended time to make the grades.
The other things are what is killing me on the truck. Alternators that come apart in the middle of nowhere, garbage rebuilt injectors that took me a year to track down, AC system failures on extreme heat days, electrical issues, constant exchange of lifetime warranty parts... :mad2: The little cr@p adds up to about $1,000 a month in parts. Then there is the upgrades to the exhaust and cooling system. The labor costs me time - I could not pay a shop to do this. The poor quality parts no matter what kind I get is enough to make you want to burn the thing. The fun part is doing work on this truck and getting it back on the road for the next day! That is haul, find issues, get parts, let the truck cool while I sleep, and install parts on cold truck, then it hits the road. Did I mention repairs to the cargo trailer? - lights, wiring, springs, brakes, bolts that fall out of the sheet metal, tires, tires, and more Chinese garbage trailer tires!
So if the block cracks out it is gonna cost me $1200. If an injector fails or I drop a bolt down the intake it is $1200 for a used 6.2 engine guaranteed to run and proven tough enough to get some more miles out of it.
I do not see any benefit to getting an Optimizer for a pickup. It does not have any more power. So I will still have DOT hours of service limiting me over a different truck because of slow going on hill pulls. The 6.2 will take the truck to 400K miles from a 200K replacement. Maybe it gets 100K and you are at 300K on the clock with a blown engine. $1200 is easy to justify for another used engine, but, 300K what condition is the truck in and what are other parts costing you to keep it rolling?
