Turbine Doc
Just Another Diesel Guy
I'm not wanting to pick a fight so please don't shoot the messenger, but from your 1st videos you are having engine problems maybe minor but something just isn't correct and off just enough for the ATT to not work correctly, & while ATT did not work for yours it should have regardless what your consulting experts have said; unless you have some really oddball driving style or engine/setup configuration something isn't adding up here.
I'm well versed in what Bill Heath may have said if he was one you choose not to mention; he is one of my regular "go to guys" we have spent hours of discussion/debate on this as he was making tunes for mine so much so we have each others personal cell numbers in each others phone, what it boils down to many trains of thought no 2 mechanics/race teams agree on same way to skin a cat/win the race.
Example where we agree same concepts but different ways of getting there; for Bill to make his record setting runs at Bonneville he needed 2 things more air & more fuel he went with twin turbos which work but require more to fab than a ATT install & my FTB fittings are on his LSR. Which when I came up with feed the beast idea and sent him my fittings for test he nixed that idea when I first proposed the need for it him saying the standard h/o lift pump was plenty for performance or h/d tows and me going with FRB-5 and fittings yet him eventually reaching same conclusion going with air dog h/o lift pump.
That said in spite of his negatives toward the ATT we have come up with what I believe to be the correct program match for that turbo it just required persistence my part and time his part to come up with the correct combination. At one time the earliest reflashes he produced were directly compatible to a ATT installation, I know as I ran all of them he put out at the time, some ran well so not so well, depending upon where you fell into the genesis of the tunes he was selling you may have gotten one that does not run well with ATT.
The back pressures in the GM-X turbos will/can mask problems in a high mileage vehicle & I would surmise from what I saw in your 1st videos posted; a similar setup GM-X turbo with a fresher 6.5/injectors/IP/valve train would outperform with same turbo to turbo setup against yours, and that a healthy with a ATT would toast it, too many successful installs with it to lay problems wholly at the turbo.
Is the ATT the only turbo that will work with the 6.5, nope most definitely not as others are proving in their testing, it is one works that well on majority of those it has been installed on I can count on 1 hand that ones it did not work on that I know about and it was found later in those that there were other issues with the vehicle it was installed on; adding to that with what I see in your vids pre, post, and back to GM-X turbo any turbo you try with lesser back pressure than the GM-X is probably going to leave you less than satisfied.
It is unfortunate it did not work for you & that you did not find root cause for your vehicle not being able to work with it as you will not be reaching the full potential with the GM-X turbo which is adequate for many it does have its limitations.
