Big T
I might offer this guy $4K max due to the dent in rear driver's side panel:
https://sandiego.craigslist.org/nsd/cto/5329562455.html
I ROUTINELY get OVER 20 MPG out of mine driving on the interstate. I average 21 running 70-75 in my BURB, and the best tank has been 23 so far to date(would have been higher, but trying to keep my foot out of it for that many miles is TOUGH!). And I've personnally tuned SEVERAL DURAMAX trucks that all get 20-21 running down the interstate with stock size tires. So it IS possible. The problem is MOST people tend to not drive with an egg under there foot, which kills MPG, or they do more stop and go than actual true highway driving.Yeah, whenever someone says they are getting 20+ mpg out of their diesel, chances are they are over exaggerating, can't calculate mpg correctly, or are just flat out lying. I've never had any diesel (Duramax, 6.5, 6.2) ever get better than 15 mpg....with the exception of my k2500 suburban. It was getting 18mpg when I got it. I have no idea what I did to make it hate me, but now I'm lucky if I see 15.
I should mention that I tow a lot with my diesels, with the exception to my suburban. And they have all always averaged in the 12-13 mpg, in stock form, in modified form, with stock tires, or with larger tires, they all seem to get around the same mpg regardless.
I have averaged an HONEST hand calculated 18mpg with mixxed driving out of my burb with a duramax in it. Last trip towing our 32 travel trailer averaged 13 over the whole trip with alot of back road driving mixxed in. When I had my 6.5l in my burb with 4.10 gears, I got 17-18 running 68, but if I bumped to 70 it dropped to 15.
Especially when I always figure on putting 2 to $3000 in extras after I buy it. It would be a very rare find if one had the bypass filter, engine oil cooler lines, new wiring harness, Fluidamper, 97 or newer air filter box and Amsoil front to backI ROUTINELY get OVER 20 MPG out of mine driving on the interstate. I average 21 running 70-75 in my BURB, and the best tank has been 23 so far to date(would have been higher, but trying to keep my foot out of it for that many miles is TOUGH!). And I've personnally tuned SEVERAL DURAMAX trucks that all get 20-21 running down the interstate with stock size tires. So it IS possible. The problem is MOST people tend to not drive with an egg under there foot, which kills MPG, or they do more stop and go than actual true highway driving.
With the budget listed though, I would not be looking at a diesel. Anything in the $3-5K range for a diesel is going to be high milage, or in need of work, and in the long run is going to cost you more in the end.
Fuel economy has gone down since they changed the diesel. When I first got our 98 Suburban, I averaged 18 mpg pulling a camper home from Pennsylvania.
All I'm saying is that I always hear people bragging about how their diesel (6.5, Duramax, powerstroke, whatever they have) get 20-25 mpg all the time, . . .
I'm with 3500_6.5. Have owned 3 K2500 4wd Suburbans with 6.5 and the best mileage has been a little over 17 mpg at 70 mph for the '95 (since wrecked). . . . All of them have had 4.10 gearing.
The driver has THE MOST to do with it. We had 2 drivers that would switch trucks by a wacky schedule, and the difference was obvious. . . . One guy accelarated slow and coasted before stops, and the other guy thought his last name was Andretti.
Driving our 01 suburban 6.0- my wife got 15.1 mpg and I got 12.7.
Ahhhh . . . Seeing as we are opening up the scope to *all* light truck class diesels . . . My other rig has 3.73's, 4WD, a ZF, highway tires, direct injection, and gets 19 - 20 around town, 21 - 22 highway, and 14 - 18 towing our 'smaller' 32' 5500# RV. Got 10% less mileage when I briefly ran all terrain tires (which was one of the reasons I sold them to a friend and put HT's back on). Also, only modifications I did to it were the air intake and replacement of dyno lubes with synthetic; other than that it is still bare bones stock.
A buddy gets low 20's highway in her mid 2000's Cummins and do not recall whether she did any mods.
And therein lies the real storySo in reality, there are many factors that go into mileage where it is not just the motor. Also, all of the same factors will drag down mileage in a gasser.
I'm using 2 stroke in my fuel and notice a change for the worse if I put too much in tanks....
Exactly. The btu in 2stroke is low and has a very low flashpoint. When you add it to the fuel you are degrading the fuel. The reason to add it is it extends the life of ip & injectors enough to save "X" amount of $. As long as "X" is greater than the cost of buying it, and the reduction in mpg, you do it.
When it is not a noticeable savings, you don't. Which is why my suburban never got any of the maintanence, only what was required. Now I'm going to sell it for $2,000 less than a comparable maintained one. WAY MORE than $2,000 saved in the 13 years Ive owned it. Fuel mileage is a factor to consider, but if you put in $1,000 a year of goodies and goo to do it, you have to drive the miles to pay for it. Maybe fill in for WarWagon while he's on vacation or something to justify it.![]()
Yes, the longevity of IP and injectors is the only reason I use it and my Burb is a keeper. I learned log ago not to invest big into any vehicle I will not keep........Exactly. The btu in 2stroke is low and has a very low flashpoint. When you add it to the fuel you are degrading the fuel. The reason to add it is it extends the life of ip & injectors enough to save "X" amount of $. As long as "X" is greater than the cost of buying it, and the reduction in mpg, you do it.![]()
