chrisk1500
- Messages
- 875
- Reaction score
- 0
I have been questioned many times about the ability to swap injectors in a couple of hours.
Some believe that I can, most don't believe it. Either way, here are some tips/tricks that allow me to get it done in just under 2 hours.
1. a) - wash the engine compartment with a pressure washer or a garden hose and some engine degreaser. No need getting dirt in the new nozzles.
1. b) Make sure you have the right socket. You can get the proper socket from OTC or SnapOn. The proper socket has provisions for the return line nipples and also has a hex head on it for the use of a 7/8" wrench.
2. Disconnect the injector lines at the injectors and take out the screws that hold the clips onto the bracket on the valve covers. Gently bend the lines upwards keeping in mind that they don't have to move very far to remove the injectors.
3. Pull the old return lines off with brute force. Don't screw around with trying to get pliers on the clamps. You should be installing clampless return lines with the new injectors anyways. Trust me, you won't wreck the old lines or clamps. I have done it half a dozen times now.
4. Don't remove the turbo. Just take the heatshields off. The shields are held on by screws and tabs. Take out the screws and give the shield a yank. You will also have to take the shield off the turo.
5. When removing the passenger side injectors, use the socket and the 7/8" wrench. I don't use a ratchet at all on the passenger side.
6. Make sure that the old copper rings come out with the old injectors. Use a dental pick to remove any rings that get stuck in the head.
7. When installing the new injectors, leave the plastic cap on the IP line threads to keep things clean. No need in getting dirt in the injector.
8. Use a dab of grease to keep the new copper ring on the new injectors. It keeps the rings from falling off and into the land of no return during install.
9. Install the caps on injectors #7 and #8 with a zip tie before installing them. If you are careful, you can wiggle the injector into the socket with the cap installed without tearing the cap. Trust me.
10. Install the passenger side injectors first. Once you are done the injectors on that side, start the truck and let it run for a minute or two. Check for fuel leaks before reinstalling the heat shields.
Have fun!
PS - I know that the injectors will not be torqued properly. However, when I tighten them, I get them as tight as I can with the wrench on the socket and then I give the wrench a smack with a hammer to ensure that the injector is tight. I have never had any leaks so far *knock on wood*
Have fun!
