Acesneights1
Just sit in there. Then I stuck a prybar between them n an angle to turn pump. You may not need to do this with a 6.2. I used to just grab it and muscle it. But then again I was younger and stronger. Now I'm old and fat....
IIRC if the advance is stuck or no good the pump needs to be sent out but that was 10 yrs ago for me and I never really messed with trying to fix a pump. On those the only other thing I vaguely remeber was there was a check valve ?? on top that could go bad , had a small return line on it or something. It's been awhile. It just bothers me that your only seeing smoke from one bank. It should not be hard to narrow down. Either you got a weak/dead cyl or a bad injector. I'm not sure about mixing and matching long and short injectors. Might want to ask Bill H on that one. I can still mail you my old set from the Tahoe. You want them to go out tommorow ? No guarantees other than the truck ran fine with them. I changed them merely as PM given they had 160+K on them.(Hope I can find them )
I never really noticed the whole pre cup thing and I have had 6.2 ripped down to the block A few times but then I wasn't really looking either.
Sure must be nice to work on that without a turbo in the way!
You'll need a crows foot for the IP lines at the pump though IIRC The bottom ones are a PIA. I don't remember having any issues with the a/c box and injectors but then again both mine had body lifts. I can't remember if you can pull the IP with the lines on but I know I didn't.
No problem on nozzles but careful offering an Irish men free drinks..Could be cheaper to buy a new truck...:rofl:
